Spiral Saw Mortise?? http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=4637 |
Author: | crowduck [ Fri Jan 20, 2006 12:22 pm ] |
Post subject: | |
Anyone ever used a Rotozip or other spiral bit cutting tool to make a mortise? I was wondering if I drill a couple of overlapping holes next to each other making an starter area big enough to insert a spiral bit, I could then cut the mortise. Is this practical? Or dangerous? Could I use a drill press? Answers appreciated. CrowDuck |
Author: | peterm [ Fri Jan 20, 2006 2:36 pm ] |
Post subject: | |
Any method would work, it may be a little harder and more time consuming but I am sure you could get the job done that way! I would get an inexpensive router and get the job done much easier and accurate that way ![]() |
Author: | A Peebels [ Fri Jan 20, 2006 5:40 pm ] |
Post subject: | |
The rotozip spiral bits are quite flexible when used at their factory length. I don't use them for binding, But I use an abrasive wheel to cut them shorter, then to resharpen the tip. After modification I use them to cut out the mortice for rosettes, and for cutting out the soundhole. They do a good job, and the price is right. Al Peebels |
